yesterday - last edited yesterday
I am trying to make a schedule of wall Surface Net Area, that is increased by 5% after all calculations (I mean after reducing SEOs, trims etc. from gross). Is it possible to achieve something like that in some more direct way than having a separate Property with expression "Surface Net Area * 1.05"? Since I'll be doing the same for all Net Areas I'm calculating, it looks a bit excessive. Maybe there is something I wasn't able to find in Calculation Rules or in Schedule parameters?
Thanks in advance for any thoughts and ideas!
Operating system used: Windows 22H2
Solved! Go to Solution.
yesterday
Schedules do not perform calculations.
They are simply a list of what you have in your project and you can apply total to the rows/columns.
They look a bit like a spreadsheet, but they aren't, so can not perform any calculations other than simple summation.
If you want 105% of the actual values, then you have to do that with Properties, as you mentioned.
Then schedule those property values.
yesterday
Hello Barry,
Well, it seems I'll proceed with properties then. Thank you for your reply!
Diana
