2013-01-18
		02:19 AM
		2023-05-30
		01:10 PM
			Rubia Torres
2013-01-18 06:48 PM
samco wrote:
Hi all,
Currently working on a renovation project and it's looking like it will have to be built in phases. For ease of output etc I think it would be preferable to keep it all in one file.
Anyone have any advice as to the best way to structure this? I have set up the model using renovation filter...should I just put the various phases of new work on different layers? or just set up a different file for each phase?
Tis a relatively small job so would like to avoid sinking too much time into this!
Thanks,
2013-01-18 10:26 PM
2013-01-18 10:33 PM
Steven wrote:
I would use different files for each phase. I find it easier than messing around with the reno filters.
2013-01-19 12:06 AM
2013-01-19 12:47 AM
Matthew wrote:
Sadly the only (reasonable) way to do phasing is with layers or separate files.
I was very disappointed with the renovation stuff when it came out. I do a lot of phased work and it's pretty much useless to me. It seems like with a better spec to start, and perhaps a little more work, they could have had a kick-a** range of functions rather than a tepid, me too catch up to Revit feature.
2013-01-21 11:03 AM
2013-01-21 05:38 PM
laszlonagy wrote:Which I see as a notable design failure. I read this as "This was not a mistake. We intended to screw up."
I can only repeat what I said in another thread:
You guys are right: design phases would be great (design options would also be great), but the Renovation Filter feature's scope is not this wide by design.
2013-01-21 05:48 PM
2013-01-21 05:58 PM
