alexliz
Predefined schemes for Surface Schedules missing - even when in "New & Reset All"
It's all in the title, guys. Here's the backstory:
I needed to start off one of the pre-canned schedules for surfaces, I clicked on it, but it isn't listing anything from the project. I went into its Settings and saw that all the 'is in branch of' criteria are empty:
Weird, I thought. I did a 'New & Reset All' and see this:
Here's what's loaded in my Libraries:
Thanks for any help.
Archicad 29.0.2 (3200) INT; macOS Sonoma
2 Solutions
Ricardo Lopez
Hi @alexliz
Is the Archicad Classification - v 2.0 available in the Classification Manager?
Ricardo López, M. Arch.
Go to post
New & Reset All may just load a default template that may not be fully set up.
You can download language specific templates here....
https://www.graphisoft.com/resources-and-support/downloads/?section=cross-border-cooperation&localiz...
Just choose your language.
I am not sure if they will be set up any differently.
Go to post
3 Replies 3
Ricardo Lopez
Hi @alexliz
alexliz
Thank you both. I have Archicad Classification - v 2.0 loaded, but it's from a different location on the hard disk (I have exported the set from a past template) so I am guessing Archicad is treating it as different. I am now resetting the criteria based on the loaded set.
As for the New & Reset All: I was starting the new project trial project based on a template that did not include any schedules - my bad. I selected the AC28INT template and all is good.
