‎2024-09-19 01:19 PM
Hello!
I am trying to Make a template for scheduling elements in my project. I will list elements with all of the three types of schedules (Elements, Components and Surfaces) and I need a mechanism to sort with wich type of schedule a certain element will be listed. Some elements need to be listed with multiple types of schedules - ex. most elements I need to be listed with either Elem/Comp and Surf.
My idea was to create a Option Set Property and have a drop-down list of all three types and a "Not listed" fourth type. This way, I would just check the boxes as needed for any element and it would be listed with the proper type of schedule.
The problem is that when I use this property as a Criteria in the Scheme Settings box, it only works with the deafult set value of the property. If some elements have a different value selected, the Criteria dosent work and no elements are filtered to be listed in the Scheule.
Can anyone help with this matter?
Thank you.
Solved! Go to Solution.
‎2024-09-19 06:03 PM
What if you create three element Properties with the following (or similar) names:
1. "List In Element Schedules"
2. "List in Component Schedules"
3. "List in Surface Schedules"
All three would be TRUE/FALSE Data Type.
All three Properties would be available for all Classification.
Then, you need to set the value of all three Properties for all elements.
Then, when you create the Schedule criteria, you include that, for example, in an Element Schedule, the "List In Element Schedules" Property must be TRUE.
‎2024-09-23 09:33 AM
Thank you Laszlo
I think that my original idea was a bit more to the point and It's a pitty that it dosent work in ArchiCAD. Your idea is great and I think it would do the job fine. Thank you.
