Project data & BIM
Purge layers
Hi everyone,
I would like to know if there is a purge option in Archicad to delete layers that are not been in use, (like in Autocad).
Thanks for your help.
16 REPLIES 16
Ron:
Go to Work Environment > Command Layout Schemes > Menus and add Attribute Manager... to your Work Environment.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
You may not have the 'Basic' or 'Standard' Work Environment loaded.
Switch the WE or add the command to the menus in your current WE.
that does not seem to be available in mine see attached
and to Barry who suggested using standard work environment i keep an original file so I can reference any changes and it does does not exist there either
Change your WE to look for 'all COMMANDS in alphabetical order'.
THANKS
I finally got it with your help and the diagram.
For info it was eleven steps in total to get there so I made a list and diagram in case I need it again. I've also attached it if anyone else in the future needs it since these one word answers of just add "X" or use "X" are not enough for me
in the past it had a "purge all unused layers" now you have to go thru and select the un used layers to purge, far harder to do but typical of Archicad these day. I often purge the un used layers of imported files since so many have a million layers and i also purge my layers when sending a file
after experimenting I see you only have to select one not all to purge still an extra step i didn't have to take before
