Project data & BIM
Purge layers
Hi everyone,
I would like to know if there is a purge option in Archicad to delete layers that are not been in use, (like in Autocad).
Thanks for your help.
Eduardo Rolon
Still in the same place as the last 10+ versions and for a change very nicely labeled.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
16 REPLIES 16
Go to Options>Element Attributes>Attribute Manager
Under the Layers tab you can see what layers you've used in the project and which are empty. There is a button at the bottom that will let you purge your unused layers.
Ron
the purge option does not seem to exist anymore in Archicad 25 unless  its another one of their useless icons that are meaningless to their function
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
interesting I'm using the Archicad 26 version 4022 USA FULL  it is completely different and now just called attributes. see my attached attribute manager first pdf, it is now concealed under a mouse click see second pdf. I had to go to another source to find out where they hid it. Archicad must be getting paid to make it harder to use
Been using Archicad since 4.1 in 1992
Screen Shot 2023-03-09 at 1.57.58 PM.pngScreen Shot 2023-03-09 at 1.58.07 PM.png
The new Attribute Palette is different to the old Attribute Manager.
You can still have both if you add them in your work environment.
With the new palette, you have to select your attributes and right click as you have discovered.
Eduardo Rolon
In the original post you wrote 25 but in 26 it is a mess with the new backwards/stupid attributes. At least we were able to make GS include the original AttMan if not we would really be in trouble. The work GS spent on the "new" Attributes is as worthless as the amount of work they have wasted on SAF/SAM.
What I did was switch back the original AttMan shortcut to it so I don't see the abominable Attributes.
AC28 US/INT -> AC08
another Moderator
How do I switch back to the old attribute?
Eduardo Rolon
It is there under options on the basic 26 WE so you don't need to switch, just open it instead of the one called Attributes.
AC28 US/INT -> AC08
another Moderator
Mine does not look like that see attached
undefined
