2011-04-19 05:12 PM
Solved! Go to Solution.
2023-03-09
07:33 PM
2024-05-06
11:04 PM
Still in the same place as the last 10+ versions and for a change very nicely labeled.
another Moderator
2011-04-19 06:28 PM
2023-03-09 07:07 PM
the purge option does not seem to exist anymore in Archicad 25 unless its another one of their useless icons that are meaningless to their function
2023-03-09
07:33 PM
2024-05-06
11:04 PM
another Moderator
2023-03-09
11:06 PM
2024-05-06
11:07 PM
interesting I'm using the Archicad 26 version 4022 USA FULL it is completely different and now just called attributes. see my attached attribute manager first pdf, it is now concealed under a mouse click see second pdf. I had to go to another source to find out where they hid it. Archicad must be getting paid to make it harder to use
Been using Archicad since 4.1 in 1992
2023-03-10 01:30 AM
The new Attribute Palette is different to the old Attribute Manager.
You can still have both if you add them in your work environment.
With the new palette, you have to select your attributes and right click as you have discovered.
2023-03-10 02:08 AM - edited 2023-03-10 02:12 AM
In the original post you wrote 25 but in 26 it is a mess with the new backwards/stupid attributes. At least we were able to make GS include the original AttMan if not we would really be in trouble. The work GS spent on the "new" Attributes is as worthless as the amount of work they have wasted on SAF/SAM.
What I did was switch back the original AttMan shortcut to it so I don't see the abominable Attributes.
another Moderator
2023-03-10 04:26 PM
How do I switch back to the old attribute?
2023-03-10 04:58 PM - edited 2023-03-10 04:59 PM
It is there under options on the basic 26 WE so you don't need to switch, just open it instead of the one called Attributes.
another Moderator
2023-03-10 05:04 PM
Mine does not look like that see attached
