Project data & BIM
!Restored: Change Default Template Path?
When I first started using AC9, whenever I would start a new project it would default to the "C:\Documents and Settings\<user name>\Graphisoft\ArchiCAD Templates" folder. I started tweaking the Work Environment and now it defaults the to the last folder I specified -- which is exactly the behavior I want.
The problem is that I don't know what changed, and I can't seem to find any settings for this behavior. Any ideas?
Ben Odonnell
That would be here.
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
I must need therapy. I had set that while working out my profile, and it never came to mind again. Will Friday ever come?!
