2025-09-11
		09:29 AM
		2025-09-13
		03:36 PM
This isn’t a major issue, but I’d like to know if there’s a way to change the shortcut key for the Flip function (currently bound to F).
I’ve searched through the settings but haven’t been able to find where this can be changed. Normally, I prefer to bind F to Fill and P to Flip.
It’s not a big problem if it can’t be adjusted, but it does get a bit annoying hitting the wrong function from time to time.
Solved! Go to Solution.
2025-09-11 09:45 AM
You can change your shortcuts in the Work Environment.
Be sure to use "All commands in alphabetical order' a then just search for a key word.
You may find yourself chasing around in circles, because the shortcut you want to use will be used for something else.
So you will need to fix that shortcut as well if you want to have one.
And what you choose for that may be used for something else......
Barry
		2025-09-11
		09:45 AM
		2025-09-13
		03:34 PM
Options - work environment - Keyboard Shortcuts.
You can search for "Fill" there and assign F for it and then P for mirroring.
2025-09-11 09:45 AM
Barry
