Project data & BIM
Shortcut for switching stories?
Malinski
Hi! I find myself losing some time clicking stories icons in navigator. I'd like to quickly switch like I do for 3D/Plan view. I can't seem to find it on Archicad or research. Do you guys know if such a shortcut exists?
pedrocollares
You can go 1 Story up or down, with the shortcut Ctrl + Up/Down
Architect / BIM Manager at IDEIA1 - www.ideia1.com.br
Archicad 27 / Windows 11 64
9 REPLIES 9
pedrocollares
Also you can right click on the tab bar definitely on the story name part for example [0. Ground Floor] and choose the desired story.
AC 28 INT 5200/WIN 11
Lingwisyer
Guru
Bind the story up and down hotkeys to your mouse! =D
@Lingwisyer , sorry can you explain more? This way I don’t know.
I think he means changing the shortcuts! If you have a gaming mouse with side buttons you can go options > work environment > , and change from ctrl + up and ctrl + down to mouse4 and mouse5 (side buttons). I haven`t yet located those actions in shortcut menu though
Valeu!
if that`s not possible maybe he meant using a mouse macro inside mouse`s software
Lingwisyer
Guru
I use mouse macros for a fair few things. Main reason I ditched a MX Master S2 and got another G502.
I currently have bound MB6 to toggle a secondary mouse layout. In that layout, MB1 and MB2 are story up and down respectively.
Ling.
Thank you so much.
