2026-05-01 02:36 AM
Hi
I work in a small office mainly designing similar two-story residential houses, so I’ve started using a “Side-by-Side” workflow instead of relying on a template file.
My Workflow:
It’s honestly been faster for me than building everything from Favorites or constantly rebuilding a template, but I’m starting to wonder about long-term file size and stability.
Questions for the community:
thanks.
2026-05-07 11:26 PM
I actually tried the Hotlink method once, but I gave up on the idea almost immediately.
It completely destroyed my DWG setup. Because of the way Archicad handles Hotlink Master IDs, it started showing the Hotlink ID instead of the actual Element IDs I needed. Since my final handoff is in AutoCAD, having incorrect or 'infected' IDs on my layers and blocks makes the file useless for the rest of the team.
2026-05-07 11:53 PM
"Au contraire indeed! 🤣
I fully realize that being a solo Archicad user is the only reason my 'rule-breaking' works. If I had to manage 100 users, I’d be a template tyrant too—I can only imagine the chaos if everyone brought their own legacy files into the mix!
Since I’m on my own, my focus is purely on getting the work out to Structural and MEP engineers who live in AutoCAD. I’ve streamlined my process so that 90% of the documentation happens in Archicad, and then I just do a final pass after exporting to fix 'ByLayer' settings for the DWG deliverable.
But this leads to my second point: honestly, documentation often feels faster and easier in AutoCAD than in Archicad. If the final handoff is just a flat CAD file, what is the point of pumping hours into a 'perfect' BIM template? For me, if the workflow gets the job done and the engineers are happy, why over-complicate it?
I’d love to know your input—does the strict template actually save you time on the documentation side, or is it just about keeping 100 people from breaking the file
2026-05-08 02:50 AM - edited 2026-05-08 02:51 AM
Engineers should not be happy, the Architect is the one that should be happy.
2026-05-08 09:40 AM - edited 2026-05-13 01:58 PM
They do it anyway.
They know their last (and still running) projects by heart.
Copy&Paste.
2026-08-07 05:33 AM
Hi Alghgifari
In a previous practice I worked at, I found that trying to maintain the template while delivering a live project at the same time was inefficient.
Something to consider is adding a template version number to the Project Info and keeping a separate document with a running list of improvements under each version. It’s a simple, low-tech system, but it also gives you a useful record of which template version each project started from. As things came up during projects, I noted them there, then updated the template at suitable milestones and struck through the completed items.
There’s obviously a lot that goes into maintaining a template, but if I had to pick a few key things, it would be versioning, keeping a clear change list, and regularly checking library warnings and attribute growth rather than letting problems build up over time.
2026-08-07 04:52 PM - edited 2026-08-07 04:57 PM
Hi @alghgifari ,
Some tips to clean up your file:
Hope this is useful to your case.
Best regards,
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
