Placed Drawing of PMK, References Source File Path, Instead of Host File Path in Auto-text
I have an "Ancillary" file (PLN), which houses all our titleblocks, guidance notes, etc.
The Titleblocks are published as PMKs. Export options are set to keep autotext dynamic, in lieu of Baked.
The PMKs are then placed as drawings in our template and therefore every project file.
All the autotext displays as expected (eg Layout Name, Transmittial ID, Project Info etc).
However, I've only just noticed that the File Path references the PMKs file path (Source), not the file that has the PMK (Host).
It's not a biggie, but wondering if this is perhaps a bug.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
0 Replies 0
