Sloped wall Surface area in schedule
I am trying to create a schedule for walls. But i cant get the surface area calculated manually in Archicad 22 Schedule.
I have attached an screenshot. Using area fills i got gross surface area as 292 sq.ft. But using Element information Tab and Schedule i cant seem to get that number. The wall is trimmed by SEO. After looking through the Help i found this note saying SEO are ignored in calculations.
Is there a fix for this?How can i get accurate gross surface area of a sloped wall in Schedule?
1 Reply 1
In the schedules you can get the gross, net and conditional areas of a wall (inside and outside).
Have a look in the reference guide at page 1742 onwards for wall listing parameters.
Just to complicate things a bit more there are element schedules and surface schedules which are a bit different.
The first image you show is to do with surface schedules and a problem that happens if you trim the zone with an SEO - I don't think it is referring to trimming the wall.
