‎2009-08-29
01:25 AM
‎2023-05-30
01:12 PM
Rubia Torres
‎2009-08-29 02:54 AM
‎2009-08-29 05:59 PM
cesarzlu wrote:What do you need the layers of the xref for? While you can attach x-refs, the best working method is to place the DWG as an external drawing either into a worksheet or a layout and then you can show this as a trace reference when needed.
I am so frustrated with AC right now. my file is really clunky with a DWG xrefed into it, not sure why... Just selecting elements seems to be slow and requiring too much concentration. I'm not interested in binding the x ref though I want the layers separated.
Offsetting? not as easy as it should be. Anyone??
‎2009-09-01 03:30 PM
‎2009-09-01 05:18 PM
cesarzlu wrote:The beauty of placing it as an external drawing is that it will NOT bring in layers or any other attributes (lines, fills, etc.).
Will the layers be separated out or all integrated like if I was to bind the xref or place and external pln?
‎2009-09-01 10:37 PM
‎2009-09-08 05:14 PM
‎2009-09-08 05:30 PM
‎2009-09-08 06:19 PM
‎2009-09-08 06:57 PM
