Piotr Walerysiak
Sqft sqm schedule merge item issue
Hi All
I'm creating schedule that shows sqft & sqm areas, but i want to see only total values for every category. For sqm schedule only it is quite easy as you can use 'merge items' functionality:
Zone area based scheduleZone area based schedule
For sqft & sqm areas I use properties to calculate values, but 'merge items' option does not work:
Property based scheduleProperty based schedule
This is my setting for sqft area value:
Sqft area property settingSqft area property setting
How can I merge those values in schedule? Maybe there is some different approach to achieve it?
Kind Regards
Piotr
1 Solution
Piotr Walerysiak
I figured it out. The answer is to use 'merge options' that are located in header row. It was tricky to find that merging works only when below settings are applied to all columns with property values.
merge optionsmerge options
Go to post
Piotr Walerysiak
