Thursday - last edited 6 hours ago by Laszlo Nagy
Hi there, can someone help me with Label tool issue.
How do I fix text label that is outside the box but the issue is only showing on window and door schedule. Thank you in advance.
Thursday
When you say it is only a problem in window and door schedules, how are you creating the schedules?
Labels don't show in the Interactive Schedules.
Thursday
Hi Barry, I am using the interactive schedule and annotate on them using the label tool.
Thursday
Annotate is good for dimensions, but I am not so sure about text.
I can't say I have ever tried labels in the annotation - you can't use associated labels it seems, only independent.
I seem to recall posts about text moving in schedules but I am not sure if there has been a solution.
Here is one I could find ...
I am not sure what it could be.
Scale maybe or text justification?
Might be a problem to get your local Archicad support involved in.
Thursday
Hi Barry, I have been doing my annotations this way but I guess there is always going to be that one project that doesn't work the way its suppose to. From the link you sent it looks like I just either re-do the schedule or put my annotation on the layout sheet. Thank you for your help.
