2008-10-28
		04:32 PM
		2023-05-30
		12:51 PM
			Rubia Torres
2008-10-28 05:49 PM
JLKilgore wrote:Use the View with the appropriate layer combination for the Trace reference
How do you turn on and off your layers in the trace reference???
2008-10-28 07:30 PM
Djordje wrote:Using different layer combos in your work view and in the Trace reference will slow down display, though.
...Use the View with the appropriate layer combination for the Trace reference
2008-10-29 01:35 PM
2008-10-29 03:30 PM
Thomas wrote:This is true. Try selecting a view from the project map to improve performance. Plus, layers will respond to what is currently visible in the view you are working in.Djordje wrote:Using different layer combos in your work view and in the Trace reference will slow down display, though.
