Project data & BIM
View an ArchiCAD file broken down to analyze and reduce file
Gus
Is there a way to see what parts of your ArchiCAD file are making the file large? For example is it the model itself? Is it the Views? Is it the Surfaces? Is it the Building Materials? etc.
Is there a way to see these things so I know what to get rid of to reduce the file size?
Any thoughts or ideas would be greatly appreciated.
Thanks.
-Gus
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
1 REPLY 1
schagemann
Unfortunately there is no central location to view what contributes to file size.
In our experience however, it is most often one of the following...
1. Layouts
2. External content, e.g. DWGs, PDFs or JPEGs
3. Sections or Elevations, if set to automatic update they will also slow your file down;
4. In case of teamwork files, the more users are joined the bigger the file gets... only resharing will help.
Btw. If you are concerned about speed of your file - there are also other factors such as hardware and 3D modelling techniques to consider - let us know how you go.
macinteract
Design Technology Managers - all  on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
