Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Project data & BIM
Viewmaps, Layer Combos and Section/Elevation markers
rob2218
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
15 REPLIES 15
rob2218
Wow.....you have a Dell M6600 laptop as well?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Steve Jepson
Yes. It's a great little workhorse.
rob2218
Yes, though my Harddrive blew out a few weeks back. I had to spend $900 in recooping my data.
But yes, it is an amazing work horse.
And it does get hot too.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Steve Jepson
I have Solid State Drives - less to go wrong I think. No moving parts.
Now you back up automatically to a Cloud or something I hope.
Steve wrote:
My only complaint about my Dell M6600 is that it gets so hot sometimes it will run very slow. In the summer I set it over a tray of ice. This time of year I just put it outside while I make some coffee. I work this poor little thing as hard as it can go all the time. No rest at night either. I put it to work with 1/2 dozen renderings to complete before I get back to work. I set it in the window against the cold glass to keep it cooler. I have not actually seen any smoke yet but where you plug in the battery charger looks a little warped
I have a complete replacement warrantee and I am not afraid to use it.
These Dell Workstations are able to tolerate an amazing amount of abuse.
Steve,
How old is your Dell and when was the last time the interior of the case was cleaned? I have some hardware guru friends and they always tell me to have it cleaned from dirt and dust every 6 months.
Last week I just took it to a guy who cleaned it up, like the dust that is gathered in the fans, making it harder to blow out hot air.
Before at full GPU use the GPU was 82-84 Celsius. Since cleaning it never goes above 68 Celsius. A big difference. If the case was not cleaned for years the difference can become even greater.
Just one thing to consider.
Steve Jepson
Thanks for the tip Laszlo,
It is probably dirtier than I think in there.
