‎2007-04-18
06:33 PM
‎2023-05-26
11:11 AM
Rubia Torres
‎2008-04-12 09:27 PM
ArchiSuad wrote:I have happening on one of my files - I think that it's because of the cadimage wall acessories since they have caused problems in teh past but how do I tell when all it says is "errors occured"?
There is no way to eliminate all error messages. I had an instance where the "Errors occurred ..." message showed up every time I opened my elevations and the only way to eliminate the error message was to fix the error. Which I did.
‎2008-05-12 06:08 AM
‎2008-05-12 06:21 AM
‎2008-05-12 06:44 AM
‎2008-05-12 07:16 PM
‎2008-05-13 12:45 AM
Stress wrote:hey! i'm not sure that having three of them is anything to be proud of either!
Hey Mate,
At least you found 3 of your danglers.
~Archiben couldn't find any.
‎2008-05-13 12:46 AM
Many times it refers to "line number____" which I can't find in the script for the object anyway."Edit GDL Library Parts" toolbar..."Goto"
‎2008-05-13 01:47 PM
4thorns wrote:When you have opened a library part, this command is in the Edit Menu along with other helpful GDL editing commands (may depend on your Work Environment).Many times it refers to "line number____" which I can't find in the script for the object anyway."Edit GDL Library Parts" toolbar..."Goto"Line NumberFound this quite by accident one day!!
‎2008-05-13 03:58 PM
‎2014-09-04 02:37 AM
ArchiSuad wrote:Archisuad, how did you fix it if I may ask?
