Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Project data & BIM
What is ZONE NAME used for?
LeeJaeYoung
Linking openings to zone | GRAPHISOFT GDL Center
It is called ZONE NAME here.
No matter what, it doesn't appear.
No value either. where will you use it?
After looking for a while, I tried everything called ZONE.
It seems to be a Related Zone Name, is that correct?
If I'm right, please correct the documentation, if I'm wrong, please explain. ^^
AC27 on window 11
Chris Pooley
Hi Lee Jae Young,
Where are you trying to view it.
I use them as Room Names, and the zone can generate information about floor areas and volumes of the room.
If you want to see it on your floor plans, you need to check the box in your model view options
And you can update the name in the zone selection settings.
Good Luck,
Chris
ArchiCAD 19 to 27
Windows 11
Chris Pooley
Hi Again,
Sorry, I should also say, you are correct, it is related to the Zone tool.
So you find this in the Design Tab > Architectural Tools > Zone
ArchiCAD 19 to 27
Windows 11
