2022-07-31
09:51 AM
- last edited on
2025-01-30
04:37 PM
by
Molinda Prey
When I ctrl+M+shift after hotlink, the door changes
This is a case of ctrl+shift+D after hotlink and then ctrl+M.
this is door entrance door 25.
this is bbb.pln ( aaa.mod -> bbb.pln : hotlink)
The one above is ctrl+shift+M
The bottom one is ctrl+shift+D followed by ctrl+M
this is ccc.pln ( aaa.mod -> bbb.pln -> ccc.pln : hotlink)
Solved! Go to Solution.
2022-08-15 02:54 PM
When a new Hotfix or Update comes out, there are Release Notes that list all the issues and bugs that were fixed by it. You can go through the list and see if the issue you are interested in was fixed.
2022-08-15 04:13 PM
thank you so much
2022-08-31 03:17 PM
this is a known bug, AC_Wall_Direction_Type will be wrong with Ctrl-Shift-M.
There is a workaround: move the hotlink after creating the mirrored copy..
2022-09-02 07:50 AM
Thank you for the reply.
What does "this is a known bug" mean?
Are you saying it wasn't fixed in 26?
Does that mean I know but can't fix it?
2022-09-05 03:16 PM
It means others have reported it too and there is no fix in the latest released versions/updates.
When it will be fixed I don't know, it depends on many factors, please contact support about that.
2022-09-06 09:21 AM
thank you so much ^^
