2024-02-01 05:16 PM
I am struggling to add egress area and glass area into my window schedule.
I have add the IFC parameter to my schedule but it shows blank to all windows.
I am even more unsuccessful with the glass area. I just cannot find this parameter anywhere.
Can anybody help please?
I am on ArchiCad 27 UK.
Thank you
Solved! Go to Solution.
2024-02-01
08:10 PM
2024-02-05
03:13 AM
HI,
May be glass area could be obtained in a Surface schedule using Exposed Area with Glass as a Surface name criteria value.
2024-02-01
08:10 PM
2024-02-05
03:13 AM
HI,
2024-02-05 12:40 PM
I have found it, thank you very much!
2026-02-02 02:31 PM
The exposed glass area in a door or window is calculated as four times the actual value. In Archicad, glass classified under “exposed area” has four exposed surfaces.
The library part parameter gs_list_glassarea provides the accurate glass area.
