I have not tested this so this may not be correct info:
The default Work Environment Profiles are located in:
C:\Program Files\Graphisoft\ArchiCAD 13 INT\Defaults\ArchiCAD\WorkEnvironment\Profiles
I think when AC starts it loads the default Work Environment from these folders.
Try to modify those XML files, including the XML for the Profile and the XML for the Company Standards.
I guess you could save the schemes and Profile the way you want it, then in Windows Explorer change their name to the names AC uses and then overwrite the default files with these files.
It may work but you will have to try.
