Zone Volume Calculation
I have a zone that is being cut with a SEO.
can i measure the new volume and schedule it?
The zone stamp provides a volume measurement, as you can see in the attached image, which does change if do a SEO. So i am guessing its not just calculating area multiplied by height.
is this a correct measurement? and if yes how can i schedule it? i couldn't even find it in the library part parameters.
the next idea is to use the general Net Volume (Gross and Conditional show nothing). again i am not sure if its a correct measurement but the results are the same as the ones displayed inside the zone stamp.
Podolsky
Ace
Yes, ArchiCAD calculates actual volume of zone. It was introduced even before SEO - was function (and still exists) to cut zone to roof slope. So, if zone volume was calculated when it cut under the roof - why should be different if you use SEO?
I think, you can schedule zone volumes if you choose Volume in general parameters group.
