Zone Volume not calculated
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-09-29 07:21 PM - last edited on 2023-05-19 11:57 PM by Gordana Radonic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-29 08:54 PM
It is not a general issue being reported to us. We would need to know more about the actual project to understand whether this is a Bug or condition in the project that is causing the result. I will create a case in my department and email you with a link to upload the file if you please.
Best regards,
Technical Support Team - GRAPHISOFT North America
Tutorials
GRAPHISOFT Help Center
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-29 11:58 PM
I have sent you a .pla to check it out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-30 12:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-02 06:05 PM
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-18 09:33 PM
The volume calc has always been available in the past.
I've been trying for 20 minutes to post an image and it will not post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-18 10:18 PM
This may only be an issue for a user who has made a major upgrade from an older version.
Go to Options>Element Attributes>Zone Categories
The Zone Categories window opens.
In the drop down immediately below the bar containing "Edit Selected Category", make sure that some type of valid zone stamp is selected. Mine had something like "Blablabla IFC" there. When I hit the dropdown, that option totally disappeared and these options appeared:
Basic Zone Stamp
Zone Stamp 1 19
Zone Stamp 2 19
Basic Zone Stamp doesn't really have any options for content, but the other two do.
Click the dropdown for "Content Order" inside the Parameter Default Values. If you click on any of the numbered items in that list, you'll get a dropdown that allows you to select Volume as an option.
And what twisted sense of humor set up "Vapor Barrier" as the fill type? I've had to go in and change that about 8000 times over the past decade.
So, what it looks like is that I had some holdover old Zone Stamp from AC12 that didn't want to let go.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-08-18 10:46 PM
