Project data & BIM
Zone number - automatic story level
In the Zone_Stamp_2 18,
is there a way to have the room number with automatic text (story) or/and a mix of custom text + automatic.
What i need is to have the room number like this:
Zone No./<Story>/<Staircase>
for example:
02/3/4
Why?
If there is a hotlink with apartments populated on several stories one above next, the automatic text with stories number will be the only way to differ zone numbers in that vertical segment of hotlinked rooms.
Do you have any other sugestions on workflow ?
Aaron Bourgoin
I don't think you can do what you want to do without some additional scripting.
My workaround, if I understand your problem correctly is to use the 3D window in the file where the Zones live and edit more than one story at a time.
Automation? Not in this version, or the next.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
This can be achieved by mapping Zone Parameters to IFC Properties in ArchiCAD 18.
Step 1: Navigate to the File Menu>File Special>IFC Scheme Setup.
Step 2: Locate IFCSpace on the left hand panel, click upon the New Property/Classification button. Specify a Property Set Name followed by the Property Name. Click OK.
Step 3: Highlight the IFC Property and click upon the New Rule button, followed by Add Parameters. Add in the parameters required, in this scenario the parameters that'll be added are:
Zone Name
Home Story
Custom Text (Located in Add Object Parameters)
Click OK.
Step 4: Select the Zones and open up the Zone Selection Settings, in the settings tab navigate to the Additional Tags option, pop a check into the box "Show additional tags" then choose the newly created IFC Property from the drop down menus.
You can find screenshots of the steps upon the Google Drive link below.
https://drive.google.com/folderview?id=0B5u7LjNmJqn2fks2VmFYc3pIZjZaTEdDQWM0M2YyR2ZSa3NCUk5vMUU5Z3BW...
Because we've created the IFC property at IFCSpace level this newly created rule will then be used for all IFCSpaces on every story!
Hope this helps.
