‎2006-03-29
03:20 AM
‎2025-01-29
02:17 PM
Molinda Prey
‎2006-03-29 05:05 PM
Josephus wrote:I actually use two methods (and someday I will take the time to do more of the MS Word OLE.)
... does anyone have suggestions on how best to do this? i.e. create a separate drawing file for each block of text, or create MS Word files and somehow bring that in to Plotmaker (havent' done that)? Any help would be greatly appreciated.
‎2006-03-29 05:22 PM
‎2006-03-29 05:31 PM
Josephus wrote:I've usually just made independent details out of them, so you can include as many or as few groups of notes as you want without having to crop them.
Getting ready to assemble all my first project dwgs into Plotmaker. I think I'm okay with bringing drawing views in, but what is the best way to bring in blocks of text, for instance, this is a small remodel job and so I don't have a whole sheet dedicated to project info text. I do want to have flexibility to move the text box(es) around the Plotmaker sheet, does anyone have suggestions on how best to do this? i.e. create a separate drawing file for each block of text, or create MS Word files and somehow bring that in to Plotmaker (havent' done that)? Any help would be greatly appreciated.
‎2006-03-30 12:56 AM
‎2006-03-30 05:47 AM
simplest thing seems to be to just copy the text in Word and paste the text object inside the text window.Got it, thanks.
‎2006-04-05 02:52 PM
‎2006-04-05 03:57 PM
‎2006-04-05 04:11 PM
‎2006-04-06 01:04 AM
Josephus wrote:make that 3. they can be saved as a view just like the floor plan windows but the independent detail window route allows you to have both floor plan and notes window open at the same time - meaning that you can drag-and-drop notes from to and from either if you need to . . .
That's 2 for the independent detail window, I'll look into it. We just started using AC and haven't gotten as far as using the detail window.
