‎2014-06-08
09:28 PM
‎2023-05-30
12:40 PM
Rubia Torres
‎2014-06-08 09:34 PM
another Moderator
‎2014-06-08 10:23 PM
ejrolon wrote:
Yes. That is why you create "Layer Sets" and "Saved Views".
When you saved your sections to placed them on layouts you had to choose a Layer Set for that Saved View at a later date if you edit that Layer Set to turn the Furniture off then all drawings that use that Layer Set will automatically (on update) turn them off.
‎2014-06-08 10:44 PM
another Moderator
‎2014-06-08 11:04 PM
ejrolon wrote:
Time to start reading:
A placed drawing in Layout has specifc settings that you assign. These include layer sets, scale, line weight, dimension settings etc. If these settings are correctly defined then if you edit the relevant one all the drawings that are "connected" to it will change.
links:
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/interaction/navigation/navig...
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/configuration/attributes/lay...
and a tutorial video
http://helpcenter.graphisoft.com/videos/interactive-training/archicad-training-series/archicad-train...
‎2014-06-08 11:07 PM
another Moderator
‎2014-06-08 11:10 PM
another Moderator
‎2014-06-08 11:11 PM
another Moderator
‎2014-06-08 11:13 PM
‎2014-06-08 11:18 PM
ejrolon wrote:
It is something you can do after the Views are placed on the layouts. To assign a Layer Combination to different drawings.
Right click on all the drawings either by page or using Navigator View map and edit the Layer Combination
