Project data & BIM
hotlinking multiple buildings
If you have as many variations as it sounds like you have there will be no site file floor plan cut plane height that will work for all and the only solution is to switch all walls in the building models to display the 'symbolic cut'. I keep them symbolic by default for precisely this reason.
3 REPLIES 3
Thomas Holm
Save the buildings that don't behave as library objects (from the 3D window) and place them on the site.
Note that you have to re-save them when you change anything in the buildings that you want to be up to date in the site plan.
tigger wrote:
I'm not so much concerned with how it looks in plan. Its my 3D views I need to be correct.
In the site file, select the hotlinked building story and ('Suspend Groups' unchecked) elevate it in the floor plan, section or 3D window to its correct height. You select the insertion story based on what you want to see on the same story in the site plans, and then you can elevate up and down as you please.
Nick Schat
If you do the above and have the group active, select the story and go to File>External Content>Hotlink Module Settings and set the required elevation relative to your site file.
HTH
Regards
Nick
ArchiCAD 4.1–22, Mac OS 10.14.x iMac 27" 3,2Ghz Intel-Core i5
