Hi Friends,
How can I use my default modified short cut options template. I have created shortcut options and save it as template format, when I was use this it is worked well. but some times I should remove this archicad softwatre and reinstall on my PC at that time again I need to create template file, is there any option to use my old shortcuts keys created template file. I am trying to use this template file when i was open the archicad file, but this is not working. please tell is there we need to change any options.
Thanks for your help.
Nagesh
