Project data & BIM
how to hide camera in archicad ?
Hi every one as you know in archicad we can hide most of elements by putting it into layers and hiding it but in the camera set i can not put camera on the layer neither to hide it in camera setting so what is the solution for this i need not to delete it because if scenes that i will transfer it later into artlantis and to check also some interior i am designing all i need now to hide camera tempoarirly while i am working on the plan
4 REPLIES 4
The setting for that is in Camara Settings - Path Options - Display Options.
An optional way to do this is using a pen for the camera that is the same as the background in the View its in.   https://www.youtube.com/watch?v=n263Rkq1bBA
Srinivas
A trick to fake ArchiCAD to hide Cameras is to click the camera tool and activate either the VR object or VR scene, and the come out of the camera tool by pressing the ESC key without placing them, you cameras should now hide on plan view and when you want to see you cameras, just go the Camera tool again and then click on the perspective camera option to make them visible.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Srinivas, just to let you know, in AC15 there is no VR Scene and VR Object option anymore in the Camera Dialog.
Srinivas
Thanks Laszlo, haven't yet upgraded to AC 15 and hence missed that.
ArchiCAD Services
iMac, Windows 10
