‎2004-07-15
01:54 AM
- last edited on
‎2023-05-26
03:30 PM
by
Rubia Torres
‎2004-07-15 01:56 AM
‎2004-07-15 01:57 AM
‎2004-07-15 05:50 AM
‎2004-07-15 09:50 AM
lsid wrote:Probably the Material setting.
why is the siding tan 6" horizontal (model attributes ) not showing in the photorendering projection? it is only showing a flat tan colored siding with no horizontal 6" .
please help.
ac7
‎2004-07-15 11:16 AM
‎2004-07-15 11:19 AM
Kevin wrote:He is using version 7. No OpenGL ?
Your screen shot of the wall settings indicates that siding tan 6" currently only has a vectorial hatch assigned to it. As the previous message, go to materials and assign a texture, which will then be visible in both OpenGL and photorender. Your wall setting will then show a little picture next to the material to indicate that a texture is assigned.
‎2004-07-15 12:11 PM
Steve wrote:kev's right - openGL or not, the material texture shows in the photorendering window when the texture has been applied to the material.Kevin wrote:He is using version 7. No OpenGL ?
‎2004-07-15 10:19 PM
Steve wrote:Can anyone provide me the Texture for the siding so I can applied to the setting? I have checked the bundled I got in the AC7 and there is nothing on siding or maybe I miss it somewhere else.lsid wrote:Probably the Material setting.
please help.
ac7
(Options/Materials/Edit Texture)
You may need to reload the library.
‎2004-07-15 10:26 PM
