importing site dwg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-03-20
09:08 PM
2023-05-30
01:11 PM
Rubia Torres
i've gotten myself confused. i've been watching some tutorials and now i'm not sure how i should be using the dwg supplied by the surveyor. i need to prepare a site plan with my new building locations etc. i have been merging the dwg on it's own story, but is this right? i saw something done with worksheets, but it doesn't make much sense to me. i need to be able to edit the imported dwg to turn off layers and edit the info. do i place it on it's own story? it seems odd to have 2d info on it's own story. terrain makes sense obviously.
wb
- Labels:
Project Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 02:37 AM
Even for the 3D terrain - it can all be done in layers if you want.
And with turning layers on/off I don't see the point of worksheets.
Espescially as they convert all the 3D info to 2D lines and fills and they only update when you make them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 02:49 AM
wb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 03:20 AM
The problem is that you can't manipulate individual elements.
So you can explode it and retain the original layers - but you will get all the layers as set up in the DWG added to your layer list.
Now you can manipulate layers and elements as you want.
You can explode it and keep everything in the original layer that you placed the drawing in but everything will be in the one layer.
You might want to open the DWG in a separate Archicad first and then manipulate it so that it has the layers you want.
Then copy and paste into your job file.
I never really use XREFs but I think you can attach it as an XREF.
This will give you the ability to turn layers on or off but not manipulate the individual elements (unless you go back to the source DWG).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 04:50 PM
thanks,
WB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 05:23 PM
That way all the survey layers are grouped together in the manager and I have control over what is visable or not.. usually end up creating a 'Survey Hidden/removed' layer or similar so I can turn off some info but keep it in model for reference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-21 05:58 PM
wb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 03:40 AM
Set up a translateor that you can use when you open it.
The translator can be set to Feet/Inch units the same as your main file.
Also set the scale that you want the text to appear correct at when viewing the survey.
There are a lot more options you can set in the translator but these are really all I worry about.
If you always get your surveys from the same source and they are consitent in their layer names, pen colours, line types, etc., then you can get the translator to swap these to what you want as well.
Now you can manipulate the layers of this survey to get them as you want.
Then simply copy and paste into your main file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 03:34 PM
WB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 05:40 PM
To bring the dwg into AC at the proper scale, you must set the UNITS in the translator to match exactly the units for the dwg, as shown by Barry. Measure a known distance in the imported dwg to verify that you got it right; if not, rinse and repeat.
Text is another matter. Djordje gave this solution many years ago. The size of text from a dwg depends on the scale of the WORKSPACE (worksheet, floor plan, whatever) into which it is brought. So, it is important to also set your worksheet (or whatever) to be the scale of the original drawing as intended by the originator. THEN, merge the dwg. The imported text then becomes ArchiCAD scaleable text.
For example, if your worksheet is set at 1/4" = 1' and you merge in a site dwg that was prepared for printing at 1" = 20' - then the text will appear completely unusable when you later switch to 1" = 20'. Merging at the modeled dwg UNITS and into a workspace at the originally intended SCALE will get both your model to scale, and your text sized properly.
HTH,
