KURTLIN
is related zone glitched?
i have a schedule to report related zone for me so i can calculate if a area have enough glazed area and ventilation area.
i am not sure if i did something wrong or not.
sometimes the related zone cells are blank.
maybe after i save or update hotlinks.
my solution for this problem is keep delete zones and redraw it until it pop out again.
it is really annoying to do so.
can someone help me out from this suffering.
1 Solution
It could be that your zone layer has been turned off.
You should always create a view for your schedule in the view map, and make sure it has the correct layer combination that turns the zone layer on.
If the zone is not showing, the window does not know what zone it belongs to.
Go to post
4 Replies 4
KURTLIN
hi,thanks for reply. but i don't have a pc with archicad right now. i'll test it out when next workday comes.
Marc H
From my experience, the Related Zones are inconsistent.  As Barry noted, the view must be available, and even then it can be wonky.  Another issue is it can pick up or leave out elements (like windows and doors) in other stories when you have non-conventional story heights, as I often have in my projects.
My ‘work around’ is to create a grouping property for the elements and objects I need to schedule. Since the property is manually set, I do have to QC the results before publishing. However, the assignment typically doesn’t change often enough to be a burden.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Jun
Zone height needs to be checked too as, if height of zone is 0, zone information goes missing.
