Project data & BIM
layout book from ACAD 9 to 12
Suddenly we skipped from Archicad 9 to 12 and I need to merge all layout books created in plotmaker 9 to Archicad 12. Is it possible?
Would appreciate any help.
On ArchiCADWiki you can find info about Project Migration. It was originally written for migrating Projects from AC 9 to AC10 but the info mostly applies to AC9 to AC12 migration too.
http://www.archicadwiki.com/Archicad%2010
thanks for quick reply
Hi Ania,
Project migration is also covered in the 'AC12 Getting Started' PDF found on the help menu in AC12.
