Project data & BIM
mirrored hotlink missing parts
I have a hotlink which is used twice in my project. One is un-mirrored and the other is mirrored. The un-mirrored one is fine but the mirrored one looses some walls. If I delete the mirrored one and copy mirror the original un-mirrored one, the walls reappear and everything is fine until I next load the project and they disapear again!
Any one had this problem and knows what is causing it?
Thanks.
14 REPLIES 14
Erika wrote:
This is a known bug.
Mirror a copy of original pieces and create a separate module of the mirrored condition.
Erika,
Do you know if this issue is known a considerable time? If so, I hope for a hotfix soon. I have a 90+ residential project and I need to start with the siteplan...
Again, if backwards compatibility was offered by GS, I could finish in AC11 with ease...
Djordje
Ignacio wrote:
By the way, is there any 'Known issues' document/webpage/wiki for each release? (which by the way maybe should have a link from right next to the 'Update' or 'Download' button)
The Readme lists what is fixed in the hotfix
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Sure. The thing is this has been a 'known issue' since the beginning of AC 12 times it seems. So together with a list of what they actually are fixing with each hotfix, a 'known issue' list would be nice --something like 'do NOT use this if you want to use this functionality' or 'do not waste your time banging your head against this wall and use some workaround, we know this is a problem and we have not fixed it yet'.
Hi all,
At my office, we're using AC18. The issue seems to be still there.
I'm reassured to know we're not doing anything wrong but I would really like to find a better workaround then having two separate HLMs.
So has this issue evolved or are we still at the same point?
Katalin Borszeki
Hi All,
This data loss has appeared in AC18 with update #1 (it has not been present for a long time). We have fixed it and the correction will become part of the next update package (#2)! Best regards, kata
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
