ā2003-11-01
05:02 PM
ā2023-05-30
01:16 PM
Rubia Torres
ā2003-11-01 09:45 PM
ā2003-11-03 01:36 PM
Peter wrote:In fact, it isn't easier at all
Wish list - add save as .2dl to format options in publishing
Maybe this is all easier in AC8.1 ? Detail windows looks a possibility, can't you note and dimension in there ??
ā2003-11-15 06:40 PM
ā2003-11-15 06:48 PM
ā2003-11-16 05:50 AM
Matthew wrote:This of course cannot be done straight from the 3D window - you will get the 3D model.
I also tried publishing the 3D views as DWGs and adding them as xRefs.
It seems that Publisher still needs significant improvement (fixing) in its handling of 3D views.I have no objection to Publisher - does what I want - but do have objection to direct linking in 8.x!
ā2003-11-16 11:40 AM
ā2003-11-16 03:01 PM
Matthew wrote:I usually copy&paste; just recently I had to recover some general details that survived some power surges and network crashes only as PMKs.
Of course, I was thinking of a 2D view and forgot that the DWG would be 3D. It would be nice to be able to publish 2D elements though, or maybe even allow ArchiCAD to read PMKs. It does seem silly on those occasions (albeit rare) when you need to get something from PlotMaker back into ArchiCAD and have to use DWG to do it.
ā2003-11-16 07:13 PM
