2023-04-17 03:05 AM
I usually turn off the zone layer.
So nothing appears in From zone, To zone.
So I made one more floor plan and made a floor plan with the zone layer turned on, and it reappears.
I would like to know the exact method. What should I do?
2023-04-17 03:10 AM
If you need to have the zones on to get information for 'from zone' and 'to zone', but you don't want to see the zones colours, then just make your zones transparent with a Graphic Override.
I believe there is already one set up in the default template.
2023-04-17 03:15 AM - edited 2023-04-17 03:58 AM
thank you.
However, when I set the layer by creating a layer combination with the zone turned on, the content appears in the from to zone.
Is this also possible?
2023-04-17 03:25 AM
As I said, if you have to turn the layer on to see the from/to zone information, then that is fine - turn the layer on.
If you don't want to see the actual zone colours while the layer is on, you can use a Graphic Override to override the colour (make it transparent).
@LeeJaeYoung wrote:
I would appreciate it if you could take a look at my many questions about the schedule.^^
If I have an answer for you, and I have the time, I will reply.
If I don't have an answer, I won't.
2023-04-17 03:50 AM
Huh~
It turns out I put a burden on Berry-sama.
I just liked Barry's answer because it was the most understandable.
Thank you for what you do when you have time.
And thanks as always for the really clean closing of the question.
I just want to thank you for what you do. ^^
Have a nice day ^^
2023-04-17 02:50 PM
I thought it was because I had to change the layer in the schedule, but I found out belatedly that it had nothing to do with this.
What happens to the rules read from the schedule?
Are all the floor plans I made by searching for floor plans in the view map?
Or should I adjust it in the project view?
What if you need to set it up in the project view?
I want to know the principle
