overlapping zones
How to find overlapped zones ?
7 Replies 7
Dave Seabury
Pablo
Select the Zone zone tool, with the zone tool selected do a cntrl A to select
all the zones at once. Now look to see which are overlapping.
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
What if i dont trust my eyes
i mean i need to be sure ... many zones on many floors ...
Erwin Edel
Do you mean two zones next to eachother with a slight overlap, or two identical zones sitting on top of eachother? For the last one you can install the Check Duplicates tool from Help > ArchiCAD downloads.
For the first one if you make sure that there are zone boundaries setup (walls, collumns, curtainwalls, polylines, etc) you can use the Inner Edge method of automatic zones and should never have overlaps.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Gerald D Lock
We use the following system (a visual check - sorry, doesn't seem to be a way to automatically audit using ArchiCAD)
1. Set each Zone to have cover fill ON (50% foreground pen and zero background pen), and Zone contour line ON (we use a 0.25mm red pen)
2. Set a model view option (pre v20)/graphic override with no zone category fill
Overlapping % fills show up as darker colour. If the zone boundaries are not correctly aligned, the contour lines also make this obvious
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
Gerald D Lock
overlapping zones
Erick Thomas
The subject is now a little bit old but I wonder if the problem was solved? I have the same issue right now.
Erick Thomas
AC 25
Erwin Edel
The easiest solution that I also pointed out 5 years ago is to use zone boundaries with automatic updating, rather than manual drafting of zones. A lot of elements can operate as a zone boundary. Ussually these are walls and collumns, but a line or polyline can also be set as a zone boundary.
www.leloup.nl
