2009-10-22 08:26 PM
2009-10-22 08:44 PM
2009-10-22 08:50 PM
guitarchitect wrote:(I'm moving this to Working in ArchiCAD, which is the proper forum for this question.)
So I have a bit of a problem... I have an AC12 project which has one file hotlinked into a master teamwork file. Both files have gradually gone their different ways, and materials have been added/deleted from each. As you might expect (which none of us did, at the time), this has wreaked havoc on material index numbers.
How do I go about getting the files in sync, so that they share the same materials? Right now if I create a curtain wall with a new material in File A, it shows up in file B with some other material.
2009-10-22 08:50 PM
2009-10-22 08:53 PM
guitarchitect wrote:Yes, through ArchiCAD 12, you must be Team Leader with exclusive access. Or you could go back to a solo project and then share it again.
just one question - since this is a teamwork file is the over-write doable? will it be an exclusive access thing?
2009-10-22 08:56 PM
Karl wrote:While I've got your ear - we're doing a major science building in AC12, and I have a teamwork file with about 5 hotlinked files. Would it be worth switching to AC13 with TW2? Some people are finding the whole system painfully slow (5 users in the TW file seem to slow it way down), and I'm inclined to agree!guitarchitect wrote:Yes, through ArchiCAD 12, you must be Team Leader with exclusive access. Or you could go back to a solo project and then share it again.
In TW2 in AC 13 and above, you just need to have the ability to reserve the attributes for add/delete/modify.
2009-10-22 09:07 PM
guitarchitect wrote:VERRRRY worth it. If the project phase is still early, it will save you bundles of time and...$ I know GS has come up with a detailed step-by-step migration process from teamwork file in AC12 to AC13 but I seem to have lost track of it. I'm sure another user will know what I am speaking of and post a link or something.
2009-10-22 09:18 PM
ksymons19 wrote:guitarchitect wrote:VERRRRY worth it. If the project phase is still early, it will save you bundles of time and...$ I know GS has come up with a detailed step-by-step migration process from teamwork file in AC12 to AC13 but I seem to have lost track of it. I'm sure another user will know what I am speaking of and post a link or something.
If you haven't seen the new TW2 features on GS website, take a look:
http://www.graphisoft.com/products/archicad/tw.html
2009-10-23 12:21 AM
guitarchitect wrote:If the hotlinked files are an essential part of the project workflow, then I would say switching to TW2 on a fast-track project might be iffy.
2009-10-23 12:28 AM
Karl wrote:Well, you've just touched on a key part of our project (and source of my headaches). All of our consultants work in AutoCAD, and we are joint-venturing with a firm out of Boston... our drawing set is kind of a hybrid beast, as we're the "core and shell" architects and they are doing all of the interior stuff. Given that our drawing methodology (and graphic standards) differ greatly, I often end up layering our drawings together using layouts, assigning two different pen sets to each view.
TW2 itself is a huge improvement and will eliminate the complaints of slowness. But, it does not handle hotlinked files or external drawings/content very intelligently at all as none of those file are stored on the BIM Server, only the project and the libraries.
