ā2013-10-11
10:08 PM
- last edited on
ā2024-12-18
01:28 AM
by
ā2023-03-16 06:13 AM
The problem is you can have multiple elevations all looking at the same wall.
So if you add fills to all of those elevations representing the same tiles, you will get multiple quantities.
You can only have one plan and one 3D model
Add your tiles there as an object, a wall or maybe even a morph surface plane.
They will show in your elevation and you can get accurate quantities.
ā2023-03-16 07:22 AM - edited ā2023-03-16 07:22 AM
Thatās true, but you are able to accidentally schedule objects multiple times, it is up to the Architect/drafting practitioner to ensure their drawings are accurate, itās easy enough to add a modifier in a fill ID to stop it from scheduling (or ensure only fills with certain Element IDās are scheduled at all) if you wish to represent the same area on multiple elevations.
ā2024-01-11
08:51 PM
- last edited on
ā2024-01-15
12:07 AM
by
In lists you can extract the square footage of the fills, you can select which views this information will be extracted from.
I just wasn't able to insert this information as a table on the board with reference to the fill I'm using.
Does anyone know of anything like this!?
ā
