Project data & BIM
why does searching/filtering layers block: New based on selected ?
gaba
I open the layers window,
then I search/filter the layer names,
then I select the layer and want to create a copy of it using the submenu option:
"New based on Selected"... but unfortunately ArchiCAD does not allow me. Why ?
Of course, I can do this by turning off layer search/filtering.
Is there any logical explanation why "New based on Selected" is blocked when searching/filtering layers?
"When you seek knowledge, you will eventually find it. Then you will become its source - until such time as you must seek it again."
AC 7 - 27 (28), Twinmotion | Windows 10 Pro for Workstations
Dell 7740 Xeon | 64GB | RTX 3000 6GB + LG 2560x1080
All I can think of is it is because of the folders.
When you do a search it includes the folders as well as the layer.
New layer would not know what folder to put it in .
Not sure why new based on selection is not active.
However, you can right mouse click on the layer and choose "New based on selection".
Barry, thank you for the reminder!
I forgot about the context menu (right click) 😎
