‎2012-06-1901:43 PM - last edited on ‎2023-05-3001:11 PM by Rubia Torres
‎2012-06-1901:43 PM
Hello!
I have my own work environment customized to my needs.
All my schemes stored in work environment are named marko (my name).
Problems is after I assign my work environment and press OK, I go back to settings and I can see that palette scheme and work environment scheme is set to custom. Even though setting in custom and marko scheme are the same, sometimes it turns off some of my settings (show tracker gets turned off), and after restart quick layers palette disappears.
I have found that there is also another issue with the quick layer pallet and that is that it is a slightly different size the the other pallets.
You could do what I have done and create a layer pallet from scratch yourself in the work environment. then there will be no more issues with it dropping out.
