a week ago
- last edited
Thursday
Noemi Balogh
Hello there! I am using Archicad 28, with the standard work environment, and want to use the keyboard shortcut CTRL+SHIFT+D (drag a copy) and this doesn't work.
When i use the commands CRTL+SHIFT it toggles on/of the Arrow tool for Morph selections (black/white arrow).
When i add the +D (to drag a copy) it cant select an object (for example a slab or a wall) because of this reason.
If i use the same command, CTRL+SHIFT with +E (rotate a copy) or +M (mirror a copy) it does work.
Has anyone had the same problem and knows a solution to this?
I would like to hear your opinion!
Kind regards, Julian Fiole.
a week ago
Usually, one would use the shortcut after you select an element that you want to duplicate.
Basically, you select the element(s) first, then Ctrl+shift+d, and it should work.
If you haven't done any changes to the default shortcuts, and it still does not work, I'd make sure I don't have any other keys pressed.
a week ago
Hi CosminF,
Thank you for your reply.
The shortcut has worked for the last couple of years, but stopped working like 2-3 months ago.
First i select an object, then press the CTRL+SHIFT+D combination to drag a copy.
But when i try to do so, it doesn't work as usual, the (white) Arrow tool pops up and it tries to select the face of Morph.
a week ago - last edited a week ago
Shot in the dark but if you were to use the same function from Edit -> Move -> Drag a copy?
Is the same shortcut shown there as well?
You also might want to check this: https://support.graphisoft.com/hc/en-us/articles/26451021165585-My-keyboard-shortcuts-have-stopped-w...
According to that there is a possibility of a 3rd software limiting that shortcut within Archicad.
a week ago
Yes, it is indeed.
Like what i said before, the shortcuts for ''Rotate a Copy'' and ''Mirror a Copy'' do work, but the ''Drag a Copy'' doesn't...
I have searched through a lot of settings but can't find a wrong setting anywhere.
Thursday
Is there anyone else that has experienced this problem?
Can it maybe be a Windows problem?
Would like to hear some idea's, thanks in advance!
