Installation & update
SOLVED!
3D VIEW
On Archicad 22 and 23
...I coudn't see 3D of my project, because there seems a horizontal green scratched lines, why did this happen...
1 ACCEPTED SOLUTION
Solution
Lingwisyer
Guru
Looks like this? https://archicad-talk.graphisoft.com/viewtopic.php?f=13&t=70628
5 REPLIES 5
What are your system specs - in particular the video card?
Are the video card drivers up to date?
Do you still have this problem if you switch to the Vectorial engine in 3D rather than OpenGL?
Solution
Lingwisyer
Guru
Marc H
If you have not done so, you may want to also manually set your dedicated graphics card as your primary for AC (vs the integrated Intel card). I’ve found that letting the PC (or Mac) select the card for you is not a as reliable a method.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Switching to the Vectorial engine in 3D rather than OpenGL, is the best solution....
Thank u #Barry_Kelly
U help me a lot
U help me a lot
OK, so that shows it is an OpenGL issue.
The Vectorial engine does not use your video card (as far as I know).
Update it integrated video driver as suggested by Minh in the link in Ling's post.
Or better, change your system settings so the machine is using the dedicated video card rather than the built in card (assuming you have both integrated and dedicated cards).
And update the drivers for you dedicated card possibly as well.
Learn and get certified!
