Installation & update
Dimension display problem
Hello all,
I have an "interesting" problem with AC 6.5 running on Windows Vista (HP Pavilion 511n computer).
The text part of the dimensions as they appear on the drawings are sort of backwards. For example instead of reading 24'-6" in reads "6-'24. The dimensions settings are correct and the dimensions in the tool bar are displayed correctly.
I had this problem a couple of years ago when I was running with XP and I just disabled the right-to-left language setting. I can't seem to find the equivalent in the Vista settings.
Any ideas?
Thanks in advance
Ian
2 REPLIES 2
Dwight
It's Canadian electricity.
When things run backwards like that, you should flip the plug.
Dwight Atkinson
Link
ArchiCAD 6.5 on Vista??? You should try it on Windows 95! Seriously.
Link.
Learn and get certified!
