Installation & update
Info Box slow to populate
toofuerte
In AC22, I select anything and the info box takes 30+ seconds to populate and I can't do anything while waiting. I have a similar problem with finding objects, if I do a search it can take several minutes to populate the list of objects. Is there a way to speed this up?
Gerald Acton "Gary"
Acton Design Services
Windows 10 PRO 64 bit
i7-5820K @ 3.30ghz 32GB Ram
Nvidia GeForce GTX 1650 4GB Ram
AC 19 - AC 26
10 REPLIES 10
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Laci,
Thank you for the input! I would say, there are some operation of Archicad that is still single-threaded, and this could be one of them. If the core that carries out this process got overloaded, Archicad may become sluggish.
In Task Manager > Performance tab, we can switch the graph of the CPU to show the load on all logical cores. Simply right-click the graph > Change graph to > Logical processors, this will show how each core is loaded. We can identify whether something is overloading one core.
Also, at the bottom of this Performance tab, there is a button to Open Resource Manager. This program will show us an even deeper look at resource distribution. But it is quite technical, I myself rarely use it.
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
