2020-09-23 03:11 AM
> ARCHICAD-24-GER-3008-1.7.exe --help
--mode <mode> Installation mode Standard: win32 Zulässig: win32 unattended Zulässig means valid, allowedIs this still accurate?
> ARCHICAD-24-GER-3008-1.7.exe --mode unattendedand it seems it installed AC24 as 64-Bit (is there an 32-Bit Version at all?).
Solved! Go to Solution.
2020-09-23 05:00 AM
2020-09-23 12:36 PM
2020-10-06 04:27 AM
LaszloNagy wrote:I can only describe it for the Windows Installer. It's a popup. After reading about unattended install methods in the helpcenter I wanted to try it out and maybe write a script for my company.
Where is this 32-bit info? Is this in a GRAPHISOFT file? Can you tell me where? I could then forward it to GS HQ so they can fix it.
2020-10-06 09:46 AM
2020-10-07 05:17 AM
SeRohde wrote:Hello,
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
