Setup & License forum
Forum Posts
About Apache Log4j vulnerability
Dear All, Last week, a critical security vulnerability in Java logging library Log4j has been found. The vulnerability allows attackers to perform remote code execution, which means they can run any code and access all data on the affected machine. I...
Minh Nguyen by Graphisoft Moderator
  • 1255 Views
  • 6 replies
  • 3 likes
Error Message: CONNECTION FAILED
please help, We have a powermac G4 running ArchiCad 11 with the latest updates. We are receiving this error message when ArchiCad opens and everytime ArchiCAD tries to save, either autosave or manual save. Connection Failed. The file server is runnin...
Anonymous by Not applicable
  • 3904 Views
  • 4 replies
  • 0 likes
coordinates
I am using ArchiCad 11 and I cannot get my Coordinates palette to show up on my screen when I check it in the menu. How can I find it?
  • 2411 Views
  • 4 replies
  • 0 likes
Floor Joists and Gang Studs
I have slab that is set up as a composite structure, 2x12 + 3/4 plywood. Is there a way to show the joists in 3-DA Wireframe view? Also there are a few places along the partition walls where I want to show gang studs for vertical structural support. ...
  • 4232 Views
  • 2 replies
  • 0 likes
DETAILS IN SECTION CUT
Im sure this has been asked before but I could only find a few references that didnt help me. Is there a way to make your walls already have the double top plate and sill plate when you cut a section. Is done through the complex profile manager? Any ...
  • 3180 Views
  • 2 replies
  • 0 likes
multicore or multi-processor
I know AC12 exploits multicore processors. Does anyone know if that applies to more than one processor? I have a Dell workstation that will accept another xeon processor (not multicore, of course). Will I see any speed increase by adding one? Just ru...
A volume failed to mount
Just loaded AC12 and the first thing that popped up when I opened a file was a request to enter my password to our server. Then, after I entered that, I got the error "A volume failed to mount. The volume "name of our server" could not be mounted. An...
  • 3573 Views
  • 3 replies
  • 0 likes
Installed V12, Then Checked For Updates
I just loaded 12, must say it went very smoothly. This was the easiest install I've ever done. After opening our template, I went to the help menu to see if there were any updates. Heres the screen I got. What in heavens name does that mean?
  • 1820 Views
  • 1 replies
  • 0 likes
Zone perimeter calculations problems
we have been using the zones for generating overall house areas for a while now and just discovered a problem with the way the perimeters are calculated and was wondering if anyone has any solutions etc. i have narrowed it down to the use of profiled...
  • 2085 Views
  • 1 replies
  • 0 likes
